- Apr 13, 2019
- 1,957
- 48,444
- Ci Coachbuilt
- Since September 2018
We have a 2001 coach built ci motorhome known as an Arabella, based on a rollerteam type model.
It has an underslung waste tank at the rear with a slide valve arrangement for dumping grey waste.
The external diameter of the valve is 44mm and has a pair of lugs , one on each side, to take a bayonet type coupler fitting to attach a hose to, in order to get the hose closer to the ground or better,directly into the grate area when dumping at a service point or drain.
Can anyone please advise where I might be able to get one of these couplers please, and possibly the fairly large bore pipe to go onto the coupler?
Thanks in advance.
Thanks in advance.
