Minxy
- Aug 22, 2007
- 35,202
- 76,982
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
The link is a bit tenuous but it's the only way I could think of making this a legitimate MH related post!
Note that I am in no way a financial adviser so if you choose to do any of the below I bear no responsibility for you cocking-up, however if you are successful I won't object if you want to give me a "finder's donation"!
The below are just some 'perks' that we've found, there may be others so if you are wanting to make more dosh in this way have a mooch round the internet to see what else may be available.
Nationwide Building Society
They have been doing a switching reward for a while which has 2 reward payments which you could qualify for making £125 in total:
Santander
They have brought out a new switch 'cashback' reward of £130 for new and existing customers:
Virgin
They've had a switch reward for a while which has been changed a couple of times so check which one is on at the time you want to switch. One thing we've found out though is that you can have more than one single name M Plus current accounts which pay 2.02% PA on £1,000 (any amount over this in the account won't earn interest) but if you go down this round ideally set-up a simply transfer of funds into it each month so that it can be shown to be being used as a current account and not just a savings account with no transactions going through it. You don't need to leave the transferred funds into it, I just do what I call a 'ping-pong', ie set standing order payments to go automatically from a non-Virgin account into it and then have Virgin send it back again a couple of days later, once set-up it they don't need any further input.
- £100 for those who don't have an account with them already
- an extra £25 for 'members' who already have an account with them (either current or saver)
- First open a basic saver and put a small amount of money in it
- Wait a day before doing anything else as this gives time for you to be fully registered in their system and thus you will be recognised as a genuine member
- Decide which existing bank account you want to switch to NW making sure that it has 2 active direct debits on it (or will have by the time it switches) and that you are happy for this account to be closed when the switch happens.
- Apply for a current account (FlexAccount, FlexPlus or FlexDirect) and request a switch as part of the opening procedure (some of these have monthly fees so check which is most suitable for you first).
- You will be asked to select a date for the switch which will happen no later than 30 days after you request it (you'll be offered dates to choose from) - if you have newly set up direct debits on your existing account make sure it is after their first collection date so you meet the criteria of their being 'active'.
- Once the switch has happened you will receive the reward(s) within 10 calendar days of the switch completing.
- If you don't have a current account follow steps 4. to 6. above to open one.
- If you do have a current account you can simply apply to switch a non-NW current account into it along with 2 active direct debits following steps 5. to 6. above
Santander
- Decide which existing bank account you want to switch to Santander making sure that it has 2 active direct debits on it (or will have by the time it switches) and that you are happy for this account to be closed when the switch happens.
- If you have a Santander current account already simply request to switch your existing account elsewhere into it; if you don't already have an account with them apply for a current account (check which ones qualify as not all do) and request a switch as part of the opening procedure (some of these have monthly fees so check which is most suitable for you first). [Note that, probably due to high demand, it appears that their system is having a hissy fit so you may not be able to do the switch request when opening the account in which case you'll have to just open the account on-line then visit a branch to get them to set-up the switch for you - this is what I'm having to do].
- If you are able to request the switch you will be asked to select a date for it which will happen no later than 60 days after you request it (you'll be offered dates to choose from) - if you have active direct debits on your existing account they will transfer over, if not you can set them up afterwards on your new Santander account so long as you do so within 60 days of it's opening (make sure their first collection date is before the 60 days is up though so you meet the criteria of their being 'active').
- Pay £1,000 into your new current account.
- Log on to Online or Mobile Banking.
- Once the switch has happened you will receive the reward within 30 calendar days of the switch completing.
Virgin
