Did you know Victron have a new 50 B2B out next month?Last component of my lithium upgrade is a B2B and initially I was recommended the Votronic over the Victron but can anyone offer the best choice between the Votronic and the Sterling B2B please?
That's a very neat installationWe have 2 of the 30amp Votronic b2b’s, they are incredibly compact which could be an advantage depending on where you are installing it?
Your opinion is as you know good enough for me. Thanks again for your advice.The Votronic is fan cooled so can be fitted in a smaller space the Victron needs a large area of free space around it.
The Votronic also has a battery maintainer when it is off it will give a 2 amp charge to the starter battery.
Not impressed with Sterling products I personally would give them a miss.
And I have a Sterling 60A which works very well. My previous MH had a Sterling 50A, which believe it or not, also worked very well.I have a Sterling 70amp which works very well
I’m curious how often the Ablemail is needed if the Votronic B2B can trickle charge the starter battery from the leisure battery when stationery.Roadpro did a great job, 2 100amp lithium NDS batteries, 2000w inverter, Ablemail, 2 30amp b2b, NDS solar regulator, lithium charger and original cbe charger now only for starter battery. Then I spoil the job with my 2 electric bromptons and assorted junk!!
Just the opposite, in fact. The Sterling 30amp B2B works very well with our smart alternator.The Sterling appears to have a default of voltage activation which will not work with smart alternators.
The new Victron is supposed to be more efficient (and rumored to be bi directional when the firmware is upgraded) so will better, but to an extent you are paying for it's ability to integrate into a system with other Victron kit and reporting systems, if that's not going to be used, then.......The Votronic is fan cooled so can be fitted in a smaller space the Victron needs a large area of free space around it.
Must have been wired for ignition activation because voltage sensing alone will only work in short bursts when the alternator is active.Just the opposite, in fact. The Sterling 30amp B2B works very well with our smart alternator.
Yes the 50 amp Victron is supposed to run cooler than the 30 amp. If they upgrade it for bidirectional it will be a good unit.The new Victron is supposed to be more efficient (and rumored to be bi directional when the firmware is upgraded) so will better, but to an extent you are paying for it's ability to integrate into a system with other Victron kit and reporting systems, if that's not going to be used, then.......
The Votronic temperature sensor also detects over heating. The Votronic unit comes with the sensor so it’s not a big deal especially as you don’t have to connect the sensor to the battery (although it’s probably best to).Yes the 50 amp Victron is supposed to run cooler than the 30 amp. If they upgrade it for bidirectional it will be a good unit.
One disadvantage of the Votronic it won't work in LifePO4 profile without the temperature sensor which is good in some ways but not necessary if you have a battery with built in heater
Agree but it does come with the sensor in the box. (As StillGoing said) Belt and braces comes to mind!Yes the 50 amp Victron is supposed to run cooler than the 30 amp. If they upgrade it for bidirectional it will be a good unit.
I thought it was 15 quid extra so that's good.Agree but it does come with the sensor in the box. (As StillGoing said) Belt and braces comes to mind!
You pay extra for the one to go with the solar controller. I did ask Votronic if I could make the lead from one go to both B2B and mppt but they said no. I expect you could find a way to make that work but it was beyond me.I thought it was 15 quid extra so that's good.
Not at all. The alternator is active continually at 13.2 volts or more and the B2B has a timer which keeps it running for many minutes once it has been activated by engine overun, which even on French roads is fairly continually.Must have been wired for ignition activation because voltage sensing alone will only work in short bursts when the alternator is active.
Mine uses the D+The Sterling appears to have a default of voltage activation which will not work with smart alternators. Their alternative of ignition activation can put a heavy load on the starter battery before the engine is running. The Votronic uses D+ activation which in my opinion is the proper way of doing it.
A continual 13.2V doesn’t sound like a smart alternator.Not at all. The alternator is active continually at 13.2 volts or more and the B2B has a timer which keeps it running for many minutes once it has been activated by engine overun, which even on French roads is fairly continually.
Well ... It is a 2022 Ducato.A continual 13.2V doesn’t sound like a smart alternator.
I’m not sure I understand. The starter battery should be wired into the back of the EBL 30 with a 50A fuse.Well ... It is a 2022 Ducato.
The biggest problem was getting a starter battery connection to the B2B. Our 2022 Hymer Exsis has no starter battery connection adjacent to the EBL 30. (other than the 20amp connection labelled for the fridge - but actually only used by EHU starter battery charging and solar panel charging)
Do I need to take a photo to convince you. That is not how it is wired. The 50amp connection point is empty. (as is the fridge connection point)I’m not sure I understand. The starter battery should be wired into the back of the EBL 30 with a 50A fuse.
Yes that is how my 2014 Hymer Exsis was wired. But the relevant date is now 2022.This is how my Votronic B2B is wired. It uses the existing wiring from the starter battery to the EBL.
How very odd!Do I need to take a photo to convince you. That is not how it is wired. The 50amp connection point is empty. (as is the fridge connection point)
The point is "Should be from whose point off view?". And also, at what date?
This 2022 Exsis has no starter battery connection to the EBL 30. The EBL acts just as a 12 volt distribution and charger unit for the leisure services.
