I purchased a Hymer S820 motorhome 2 years ago (from a Funster) which is based on a 2003 Mercedes Sprinter 616 chassis, with 2.7 diesel engine and 5 speed full automatic gearbox (722.6 type). Most components are uprated from standard Sprinter, including the axle which is from a Vario truck, with air parking brakes.
There was the occasional slight rumble / vibration between gear shifts when I bought it, but barely audible above the other squeaks and rattles. I was told it was 'normal' and had no reason to disbelieve it as everything about this 6 ton HGV drove more like a truck than any smaller motorhome I had owned.
Noise and vibration got significantly worse last year during a trip around Europe, causing very hard gear shifts, often with a heavy thump at low speeds changing down from 3 - 2 - 1 gears and sometimes with a dragging, grinding, metallic vibration in 1st or 2nd.
Mercedes sent me to numerous dealers (approx 13) in 9 different countries (a long story for another thread) and it has been in 3 UK dealerships since March.
Numerous transmission fluid changes have been carried out, with test drives, diagnostics and adaptive resets at most dealers. Valve body and conductor plate swapped. 2 brand new torque converters have been fitted with solenoids etc, plus a heavy duty drive plate. A complete brand new gearbox has been fitted, plus a new rear axle differential. The 3 piece propshaft was my initial suspicion, but this has been removed and tested by 3 independent specialists (as well as Mercedes) who all say it is balanced and the universal joints and carrier bearings are all good and do not require replacement.
That is every mechanical component in the transmission replaced, from flywheel back. Nothing has made the slightest bit of difference and Mercedes don't know what to do....
I made a video which shows play and clanging noise when taking up drive from neutral (parked), and the second half of the video shows the other noises, plus occasional sharp 'kicks' through the propshaft.
Video here:
Problems occur when the transmission is 'unloaded' - ie neither accelerating under power or decelerating, but coasting with very light throttle matching the engine speed to the wheels. Basically how you have to drive through towns or in heavy motorway traffic tailbacks. The hard gear changes seem to be a symptom of this, as the auto box tries to match the engine speed without load when slowing and changing down gears.
Any advice or recommendations gratefully received as I can't understand why Mercedes can't diagnose or fix a fault that is this obvious .....
Video here:
