TyrePal - any discount codes working at the moment? (1 Viewer)
MH04RMV
84
141
Cheyenne 632 SE
Hello Wombles
Just been reviewing the various threads about these units, and wondered if you know whether there are any current discount codes, either from the Funsters or CAMC please?
I'm looking at a unit and probably x11 extra sensors for the other vehicles (or perhaps an "HGV" version with 16 sensors included)...so a working code might help considerably...
Thanks in advance for your help.
Cheers,
Rich.
OldCodger
796
178,655
Cambridgeshire
Carthago I 143 LE
Since 2016
Try this one
Save 20% worth up to £55 on Tyre Pressure Monitoring Systems!​
A TyrePal system can monitor your tyre pressures, whatever the vehicle. TyrePal TC215B systems allow you to monitor caravans and tow vehicles, whilst their latest TyrePal Solar Colour is perfect for monitoring the tyre pressures of motorhomes, cars and campervans.
TyrePal systems continuously monitor the pressures and temperatures of your tyres whilst you are driving and give clear visual and audible alerts should anything start to go wrong.
Sensors simply screw onto the vehicles’ dust caps – the Solar Colour is even pre-registered, so just screw them on, set your alert levels, and away you go. If you drive a 6 wheeled motorhome, just purchase an additional two TCSO sensors and register them to your Solar Colour – the screen will then flash between the front and rear axles!
TyrePal product range includes:
TyrePal are proud to announce that the TyrePal Solar Colour won ‘First Car Product of the Year 2019
“In 2013, we attached a TyrePal system to Tinkerbelle, our Trigano Tribute. During 2015 and because the display shows individual pressures I detected an issue, one tyre reading significantly lower than normal. A trip to the garage revealed a sizeable nail. Problem solved before it became a roadside disaster.
This summer we were travelling on a busy single carriageway in County Roscommon, Ireland. The alarm suddenly went off so I pulled over to investigate. Immediately I could hear air escaping the rear offside and the monitor told me the pressure had dropped from 65 to 40 psi. Within minutes the tyre was completely flat. The bottom line is, the device certainly saved us from having to deal with a flat in the middle of the road or worse maybe, a shredded tyre, Doesn’t bear thinking about! My advice, if you don’t have a tpms is to get one, pronto.
Member: R D Wilson
If you have any product enquiries please contact TyrePal Team by calling 01543 870 190 or emailing admin@tyrepal.co.uk
Visit website and use discount code CAMCTYPL22
M
MH04RMV
84
141
Cheyenne 632 SE
Thanks OldCodger,
Will give it a go.
Cheers,
Rich
M
MH04RMV
84
141
Cheyenne 632 SE
Try this one
Member: R D Wilson
Code worked a treat - thanks very much OldCodger !
Cheers,
Rich.
Wombles
10,678
10,748
SW England
Van Conversion
A few years now
Hello Wombles
Cheers,
Rich.
Fun discount here Link Removed but good to see that you are already sorted :)
Realist
1,665
2,526
Wales last time I checked.
Caravan: Buccaneer
Caravan before 2000 / Motorhome From 2018 to 22 / Now Caravan again.
Any codes going, I’m after 6x sensors so looking for a code to reduce costs.
May 10, 2023
125
1,918
Auto-Trail
If you are a member of the C&MC or the C&CC, both will give you a discount on TyrePal. Just sign in to the club websites.
May 10, 2023
125
1,918
Auto-Trail
I did say “if you are a member” ;)
