Hi, our new to us van has two tvs but no outside aerial socket. When on site with aerial plug in points will i just have to feed a cable through a window and will i need two one per tv?
As will most locker doors if laid along the long sides.through the cab door, the seal will have enough "squash" in it to close ok
no, and these work ok in normal areas,Thanks just thinking in the short term . I will feed it via roof or door. then think about permanent one outside. But if we have firestick do you need the aerial.
No aerial needed with a firestick,,BUSBY.Thanks just thinking in the short term . I will feed it via roof or door. then think about permanent one outside. But if we have firestick do you need the aerial.
no it directly inputs to the HDMI portWill one firestick work on two tvs?
