Tube heater
Essex
Low profile
Joined 2014
Hi what would people recommend for motorhome if I wanted to put in a tube heater unsure what wattage and length many thanks
If you do a search you will find many discussions and views about the pro’s and con’s of background heat over cold periods. Assuming you mean whilst not being used, ventilation is probably more important. My view is trying to provide background heat is not necessary provided you have ventilation and frequent checks.
Thanks that’s what I’m thinking now
We used a couple over winter but really they don’t do a lot,
[Broken Link Removed]
We have now changed to using a couple of small Delonghi oil filled radiator's.
I’m thinking now opposite camp no heating as mh are well ventilated not leaving bedding or towels in and opening cupboards and lowering beds slightly to create airflow
Best way, ours is unheated and all the beds made up, clothes in there. Don't need to open lockers on ours as the rear of them is spaced off the wall.
That’s quite true my wardrobe is at back so will probably keep that empty
Just my friends seem to use tube heaters and thought that would create condensation and damp
A friend of ours has a tube heater in their motorhome for background heat during winter storage. Also they put there feet on it if it’s chilly whilst they are away.
