Truma Inet
Leicester
Autosleeper Nuevo EK
Since 2012
Does anyone know how to turn the Truma Inet off on a 2018 Auto Sleeper Nuveo, we have never used it, has anyone else?
We use ours a lot and find it very useful. If you don’t need or want it you could just ignore it or delete the phone app. Why do you want to turn it off?
I know nothing about the Nuevo installation but when I fitted my iNet it involved a fused power supply and a data lead connection to the Truma boiler or panel. If you want to disconnect it I would try disconnecting the power supply and unplugging the data lead. You might also need to refresh the panel by doing an Appliance Search.
I use mine via Bluetooth only. Particularly in the winter it’s nice to be able to turn the heat on without getting out of bed in the morning.
So far I’ve not noticed a big drain on the battery when parked but I do wonder why it doesn’t have a proper power switch especially as it isn’t powered through the sergeant control panel.
In winter I shut down all the standard systems except the iNet so that I can keep an eye on the leisure battery voltage. My tracker tells me the engine battery voltage. I find this helpful because the mh is stored away from home.
