Truma combi
Silky60
Dover, UK
Carioca 694
I'm a newbie
I believe I have c series combi system with only one dial every time I turn the dial the green light comes on followed by the orange light then a clicking noise followed by the red light and the orange light starts to fade and go out the gas is working and full up as is the water can any one help please as buying another boiler is outta the question ( no funds left) all I get from truma is this one is obsulit you got a fault it needs to be seen buy an engineer I'm not gonna lie in not technically minded thanks
Is the outlet clear on the outside of the van ? also is there a window over the outlet that is open (I think sometimes a switch is fitted to a window over an outlet to stop it working when open)
Check the gas supply at source.
Hi Geoffndee just check no all clear buddy
Have checked that WillH thanks mate sorry new at this ( about last massage read wrong bit ) it's to do with old age memory lost and being total hopeless soz ken
Is gas getting through to your cooker ok with plenty of pressure if not it could be a faulty gas regulator , assuming there is plenty of gas in the bottle , another thing to check is that the leisure battery is not low on power and needing a charge.
Are you sure you only have one dial , mine has two one of which switches operation between gas and 240volts ? If only one dial can you see a model number on the boiler.
