Truma combi 6e not fireing up !!
notts
since 2010
Hi all
As title suggests really, either on 240v mains or gas the boiler control panel led flashes red and boiler refuses to start.
On gas there is no audible clicking prior to ignition. The 12v fuse appears to be intact.
Any help or guidance really appreciated
Antique
there is a fuse on the boiler circit board, have you checked that
I think there was a red re-set switch, button on the power board of the older ones, I don't know if your model has one.
Just a thought you haven't got a window open near the flue have you?, again I seem to remember there was some sort of safety cut off if the window was open.
Thanks @TCG yep cheched 12v fuse and it's ok
Thanks @Eggs yep tried red reset button, It hardly moved when pressed but didn't want to force it
Is there water in the boiler? Is there gas? Is the gas on? Have you selected 240v rather than gas or mixed?
If there's no display of the error code, the main board displays a flashing LED of the code.
when I have had problems in the past I have rang Truma tech dept , and they have always been helpful they will ask you for the fault code which is the flashing lights on main pcb
Phone help
You need urgent help because your Truma heater is not working properly or you have a question about how to operate it – simply contact Truma Service.
E-mail: technical@trumauk.com
Excellent service from often maligned Truma.
phew! :clap:
Excellent service indeedy (y)
And a very large PHEW @Oscar !
See you tomorrow
