Truma Combi 4 E Strip down & replace heating elements (1 Viewer)
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
My boiler does not heat water using the electricity. As far as I can tell there are various warning lights to indicate most problems but indicate that the heating elements are kaput other than the fact that everything looks normal at the controls but the water just refuses to heat.
Before starting to work on the boiler, for safety, I turned off the mains electric hookup, switched off the 12 volt power system and turned the gas off at the gas bottles in the gas locker. The van has not been used for a couple of months.
I have checked the obvious things like live power to the boiler, fuses not blown etc but nothing. I haven't found any videos or pictures of how to do it so I'm going to take you through my attempt to replace the heating elements which are currently on order at the extortionate price of £309!
You have to access both ends of the boiler so it probably needs to be removed from your van and put on a bench. To achieve this you need to disconnect both the mains and 12 volt electric cables. I have taken a photo of the 12 volt connections so that I can put them back in the right places on the printed circuit board. There are 4 hot air tubes to be removed which are held in by 4 philips headed screws. There are hot and cold water connectors to be removed so make sure that you have emptied all the water from the van and boiler before removing these. The gas connection needs to be removed which needs a 17mm spanner. The exhaust pipe has an outer sleeve which needs to be removed which again needs a philips screwdriver. Inside there is the exhaust pipe with a clamp that on my Autotrail Savannah 2010 has a star drive screw. There are 4 large philips screws holding the boiler to the floor.
You can then lift the boiler out and as its made mostly of aluminium its not too heavy. I rested mine on a garden bench with the water outlets downwards to let out the remaining water.
Here its is now on the dining room table ready for dismantling though the electric overs have already been removed. The top 12 volt cover just unclips. The 230 volt cover needs to have 2 star drive screws removed at top left and top right. I have also removed a cooling fan cover which just unclips and slides up.
Photos to follow shortly!
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
Now we need to take the cover off the other, left hand end when looking at the Electrical Printed Circuit Boards. These have star drive headed screws.
The next picture shows that the outer cover has been removed to reveal an further, inner cover which needs to be removed.
View media item 22826
The inner plastic cover now removed and the 4 wires removed from the ends of the heating elements which are held on with 7mm nuts with 2 star locking washers either side of the electrical connector.
View media item 22827
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
In theory with both ends of the heating elements now revealed and disconnected we should be able to remove them by pulling them out from the U shaped end but they are rock solid and won't move! On the end with the 4 heating element electrical connections I next removed the 4 rust coloured oval shaped grommets and then removed the aluminium cover plate. This needs to be teased away carefully as there is a rubber gasket holding it in place even after the screws have been removed.
View media item 22831
Just as a point of interest the hole in the middle is the gas boiler combustion chamber and contains a stainless steel sleeve.
View media item 22832
As a further point of interest here is the gas burner with its lighting electrodes
View media item 22833
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
So we are now fully dismantled far enough to remove the elements.
The following picture shows the ends of the heating elements and there is a free length of each element not between the fins of the heat transfer unit. My only choice is to drift these out gently using a wooden or rubber mallet choosing one element first and alternatively tapping each side to gently knock it out at the other end of the boiler. That's as far as I've got tonight so I'll carry on when I can tomorrow or later.
The next three attempt to show progress drifting out the elements
Mr B
992
1,901
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Great thread. Really informative.....
Now I know where the reset button is.....;)
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
Yes the real problem with the reset button is that it is not visible until you remove the 2 screws for the main cover to the electrics and then you realize that there is a sleeve in the plastic cover which you could poke a screwdriver down to press the rest button! It must pop out when it needs resetting. I initially thought "red button" - I haven't got one of those until I found it when I took the cover off.
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
I should have mentioned this at the start but you ought to test your heating elements with a multimeter first to establish if they have failed. A heating element should have a resistance if it is OK. Here is how to calculate what the resistance should be and how to do the test.
https://www.wikihow.com/Test-a-Heating-Element
Mine both have no resistance whatsoever!
However as can be seen you have to get a long way before being able to test the resistance of your heating elements!
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Don't forget to use new rubber gaskets and seals on the burner assembly when you rebuild it. When the elements fail they often split and swell (which is usually what makes them difficult to extract. This also spreads the sections of the heat exchanger where they fit, you need to remove the heat exchanger and gently squeeze these sections to close them up, there is a specific dimension for the gap, Ill see if I can find it for you. If you don't do this then the new elements will not make proper contact with thew heat exchanger meaning performance will be poor and also that the new elements can overheat and fail prematurely.
D.
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
So I've now drifted out both heating elements and it was not an easy job. Both were stiff inside the tube drilled into the fins. Don't set about this unless you have something small enough and which won't damage the tube in which the heating elements are located. I was fortunate to have both a long and a short 1/4 inch drive socket set extension bar which combined gave me just enough length to drift them out. The long one is 9 inches long and the short one 4 inches giving 13 inches total length.
Here are pictures of the extension bars at the heating elements now removed which are 15 inches long and I could pull out the last three inches or so.
Clearly the heating elements need to be a tight fit inside the fins to enable the heat transfer but I have to say that I am concerned at how I am going to get my expensive new heating elements back into the boiler when they arrive given the efforts with the mallet to get them out!
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
D.
Thank you very much Dave. I am fortunate that I don't have split elements and apart from some light corrosion/rust on the elements they look in pretty good nick considering they have both failed.
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
So the new heating elements arrived along with a comprehensive gasket set and 2 packets comprising a complete new set of nuts, screws, bolts and washers. Attempting to fit the new elements and one pushed in with some slight resistance but the other one would not go in and I decided that it should not be drifted back in having seen Dave Newell's helpful post above. So some further dismantling required to remove the stainless steel hot water tank from the heat exchanger fins to expose them and adjust their tightness to allow the new heating element to be fitted. This is just a question of undoing the nuts which hold the boiler tank to the heat exchanger. When you think you've done this and expect the tank to come off it still won't budge so I felt all around the edge of the tank checking it was free or maybe stuck by another gasket but no there was a tight spot at the top. You then realise that there is an aluminium insert where the mini fan housing was located. Removing this exposes the last nut holding the boiler tank in place. Remove the tank and then the heat exchanger fins are exposed and can be adjusted in or out so that the new heating element can be inserted. Some more pictures follow.
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
Oct 29, 2008
5,078
5,993
West Yorkshire
Rather than drifting the elements out how about putting a broad webbing strap through the loop end and pulling out?
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
With hindsight I would have removed the stainless steel water tank from the heat exchanger which I ended up having to do anyway, adjusting the aluminium fins to enable removal and re-fitting of the new heating elements.
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
Its then a question of refitting everything back onto the boiler in the same way as you took it off. Hopefully this thread will help others.
My boiler is now ready to refit into the van and then I can reconnect the cold and hot water pipes, gas, electrics and air tubes ready for refilling with water and testing.
53,693
150,968
Great thread thanks for all the info. Are you going to put the info in the resources section?
It has convinced me I have made the right decision with all 3 vans I've had by just having the gas only Truma. :D
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
Thanks for the suggestion Lenny - now done with a link to this thread.
TCG
Jul 6, 2017
1,366
2,047
Salford Priors
Autotrail Delaware
Excellent to read. however i would not have the capability or patience to do this. fair play to you.
Do truma not have a replacement/ refurbish programme... if not and mine go can i send it over to you :)
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
My motorhome is not just a vehicle to go on holiday but its also a hobby and I'm happy to do jobs like this to keep the running costs down if I can.
However I'm not interested in starting a repair business for third parties despite your faith in me!(y):D
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Great thread @Abacist, and particularly useful as I have just discovered that the electric heating side of my Truma Combi 6E isn't working.
It still works on gas but not on electric.
As we need to use the MH to go to a steam rally very soon it is a roundtuit job.
That is, it can wait until I get around to it.
Our Truma is buried under the fixed island bed in the rear of the MH and access is very limited, so it may mean taking the bed to bits to make things easier.
I have enough jobs on at home at the moment so it is low on the list of priorities.
mike1
As said a great read, and very very useful guide. Someone on Ebay is selling replacement elements but no gaskets - do you think the gaskets are re-useable, if you hadn't purchased the full Truma kit?
Abacist
Abacist
3,798
11,185
Devon
N & B Arto 88F Tag
since 2013
I would not like to do this job without replacing the gaskets. The one sealing up the gas combustion chamber had obviously got very hot many times and had become stuck to the covers and become brittle after 8 years of use since new and it did not survive taking it apart. The gasket is obviously ensuring that exhaust carbon monoxide does not enter the van and is therefore critical to safety. The black gaskets I would say are critical and the orange ones less so but it depends if you can get them off OK, intact and providing that they are in good condition. You might find someone has the gaskets for sale separately.
mike1
I guess thats why Truma stopped supplying the elements on their own.
ozzydakar
great post ,realy well done , did you take any video of this , as i have the same problem many thanks
