Having a prob with thetford cassette, every time draw water from bathroom sink water starts flowing into the toilet and stays running for about 2mins, any ideas, poss airlock??
Sounds like your toilet flush is being activated by the bathroom tap perhaps the wiring is crossed or shorting between the two might be a good idea to take out the toilet flush switch and check the wiringHaving a prob with thetford cassette, every time draw water from bathroom sink water starts flowing into the toilet and stays running for about 2mins, any ideas, poss airlock??
Yep kitchen tap also starts toilet but not a flush just runs In, slow flow you might saymy guess is the solenoid valve on the toilet is passing and its only apparent when the pump is activated by another tap ive never had to work on mine but others on here have said i can be removed and cleaned run the kitchen tap to see if toilet runs to confirm
Oops repeated my self there (CRAP ON A PHONE KEYPADSorry for the late reply on way down to Murcia, in Zaragoza at the moment on way down to Murcia, will have time there to have a proper look and ask for more info.
Cheers Tony
If you can't suss it out yourselves then Hispavan in Antas are fairly close to Murcia (1.5 hrs drive) , and are very helpful.on way down to Murcia
Does anyone know where the solenoid is? Staying another night in Zaragoza so got time to have a look.Yep kitchen tap also starts toilet but not a flush just runs In, slow flow you might say
That's great Cheers, will have look seen something that may be it with a 5a fuse holder in there.Depends on the model but it is usually visible when you remove the cassette,I had to change ours once and had to dismantle the toilet which wasn't to bad a job.I'm sure there's a video somewhere.
