Trauma s 5002 problem. (1 Viewer)
Davie
Hi all.
I have a trumatic 5002 s heater
It will not fully light cold or hot
It' a double fire and the back will light via the ignitor however the front requires me to drop a match in.
Could anybody shed any light of this as it has me stumped
Cheers
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
did it work before?
Do you have a user manual?
I think the burners have separate igniters, so the front one may have failed. (didn't know you could light with a match. I thought they'd be sealed.
D
Davie
It used to work yes.
It has a inpection chamber I spose you would call it match in there does the trick.
I can only see 1 ignitor and the wires to the auto ignitor box with the batteries.
Has thrown me completey
D
Davie
Yer co is working right.
It' not caused any problems it' just annoying more than anything just wanted to get it sorted.
JJ
Mágica
May 1, 2008
19,259
48,048
Burstner Privilege T
over 50 years
Do you have the battery operated igniter?
If so... try a new battery.
If, after lighting front section, the rear seaction doesn't light then I suspect the control valve.
JJ :cool:
andy63
4,672
15,017
south shields
since 1990
Sounds like its simply your front ignitor not working...and im asuming it will be the same unit serves both burners... i can only think that you will need to access the front burner and ckeck the ignitor wiring and electrode to that burner from the ignitor unit...
Andy..
