Trailer hitch lock while mobile? (1 Viewer)
David Guthrie
63
18
Northumberland
Fiat Ducato Hi-Top
Hi. I want something that will secure the trailer hitch handle, partly as an anti-theft measure but mainly to ensure that the hitch handle doesn't lift and disconnect while driving.
I've seen it stated that these locks shouldn't be used while driving as they may interfere with the mobility of the ball joint, but I'd have thought that something should be available to tackle this.
The trailer is an Erdé 102.
Views and suggested products would be welcome. :)
43,400
50,036
I don't think locks made by the hitch manufacture will interfere with the hitch operation but if there was to be an accident or fire the emergency services couldn't unhitch the car, caravan or trailer.....
43,400
50,036
I'm sure the erde range use basic pressed steel hitchs.
Other than the standard (and useless) insertable brass lock barrel I've never seen a hitchlock for these hitch other than the ball and U bolt type.
To stop the handle lifting, which is highly unlikely, you could fasten a plastic tie-wrap around the handle and body.
Jul 29, 2013
9,083
18,777
Salisbury
Hymer B678DL A class
Mine has a built in lock which I lock all the time we are using the trailer it could prevent as you say hitch lifting but also someone stealing your car and trailer.
Gellyneck
9,402
18,827
More than toes wet now!
If it's mainly as a "peace of mind" why don't you just put a long U-bolt over the hitch handle and a bar under the drawbar? Having said that never fitted anything to our Caddy trailer but we don't leave it unattended.
Jul 29, 2011
2,700
22,458
Urmston, Manchester
Former owner.
June 2012
Simple solution that works for me, can't lift hitch whether it's on the car or sat in the driveway.
David Guthrie
David Guthrie
63
18
Northumberland
Fiat Ducato Hi-Top
Thank you one and all for your input. I like the idea of a plastic tie. I think I have a fair old stock of them. And, yes, it is mainly a question of peace of mind. I have a wheel lock thing for when parked at, say, a service station.
Ooooh, d'you know, I'm having ever such fun prepping for this France trip!
icantremember
8,348
17,576
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We have the same hitch on our a-frame and have the lock which is still in it's packet!:rolleyes:
PS Hope nobody can read this ... don't want to start another battle.;)
43,400
50,036
Looks a decent bit of kit but a determined tea-leaf will unbolt the hitch and replace with their own.
Alko and box type locks cover the fixing bolts so it's impossible to remove the hitch without removing the lock and of course, once the locks off there's no need to remove the hitch..
David Guthrie
David Guthrie
63
18
Northumberland
Fiat Ducato Hi-Top
Looks like there's no simple way to solve this one. I'll go with the cable ties and wheel lock, I think.
11,961
16,579
A
Determined thief will carry a battery-powered angle grinder! To secure an unattended trailer on site or when stored takes a lot more than any hitch lock. I like the Bradley hitch when stopped in motorway services or Supermarket car-parks or on most sites. Mainly because it is easy to use and never forgotten. Bolts aren't too hard to thief-proof anyway - just use a conventional nut, socket-head bolt, and a dab of weld.
43,400
50,036
My trailer has a pressed steel hitch by Alko .
You can lift the lever but it won't release the ball until a trigger, under the lever, is pulled and the lever lifted even further.
You can see the trigger and safety pin in the piccy
It won't cure the security problem but will definately stop the cup becoming unhitched.
Aug 18, 2014
23,933
135,241
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
And if you drill right through the side,just in front of the first bolt hole you can put a bolt through and drill opposite end and use a padlock.cant lift even using trigger or come off.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Assuming your erde trailer is unbraked then by law it requires a secondary connection to the towing vehicle. This is to ensure that if the normal hitch detaches the trailer will still stay with the towing vehicle. Secondary coupling could be a short length of chain attached to tow bar and trailer drawn at for example.
D.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Shouldn't that read 'the trailer will destroy a fair sized portion of the towing vehicle'
Not really, the secondary coupling should ensure the trailer doesn't run away from its towing vehicle and run into something or someone else. Obviously it will cause some damage to the towing vehicle but that should be significantly less than a 3/4 tonne trailer bowling across a road at 50 mph and running into an incoming vehicle would cause.
D.
David Guthrie
David Guthrie
63
18
Northumberland
Fiat Ducato Hi-Top
Aye, that's very true, @dave newell lvs and @pappajohn . I've done enough drilling to last me a while, but may just do that when we get back. Meanwhile, we're trying to work out how to set up the Harrison Enclosure on the Fiamma 45 Elegance awning. What a carry on!. And it's not even really a drive-away, relying asd it does on the Fiamma awning as a roof! I'm going to stop worrying and just get on the road. Leave the fretting to 'er indoors. :)
43,400
50,036
D.
It was a tongue in cheek comment Dave. :D
I did have a major mishap many years ago with a trailer.
Single axle unbraked box trailer about 6ft6in x 3ft6in slightly :whistle: overloaded with rubble and soil.
The hitch remained coupled but the wheel, hub, swing arm and rubbers parted company.
The indespension body split open due to heavy corrosion.
The free parts overtook me as the trailer acted as a ground anchor and the wheel etc dived between two parked cars hitting a garden wall before stopping....never damaged anything luckily.
Thank goodness it was a quiet town back road and not a main road.
Ever since then I've been a stickler for trailer maintenence.
558
617
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
We had one of these for locking our trailer Alko hitch, it doesnt interfere with a standard Alko hitch it simply encases the release handle in steel and has a lockable pin underneath making it impossible to unhitch.
We always towed with it in place as it meant you could park up without fear of some wideboy nicking the trailer while we were away.
Amazon product ASIN B004DE8MTK
It also comes with a ball thingy for the hitch itself when the trailer is off its hitch that again stops anyone hitching up to it
