Yes, I think you are right - it is the spark generator. Just saw the 12V symbols on it and thought a good place to start to trace the 12v power?Maybe I'm wrong, but I think the black box has nothing to do with it. I think it's the gas igniter module.
The installation instructions say the 12V power to the fridge heating element must be a separate wire going all the way back to the battery, with its own fuse, probably 20A. It is separate from the 12V supply that powers the control board.
The two heater elements are inside a metal can, filled with insulation, two wires per element. Be careful, one of the elements is mains 240 volts. This can is on the right, above the gas flame.
Yup, wrong again . It's the gas igniter module, but it looks like it's also the connector block for all the other wires.Maybe I'm wrong, but I think the black box has nothing to do with it. I think it's the gas igniter module.
The current spec for this type of push-on connector is about 16 amps. Powering a fridge heater element is working right at its limit, so if it's not perfect it will start to heat up. The heat degrades it and it just gets hotter until it fails.Ours was a poor connection as above next to the engine battery
Can see what you are saying but I don't think the element is getting any power and I don't know where to check
No only a 1 year warrantyis it covered under warranty then? dont replace or repair if it is !!
yes i have no problem changing the element except this is a fair size fridge freezer to pull out i am not understanding where it gets its signal fromin that case i would still think about replacing it as a first option, even though you dont know if it has ever worked, though i can see why you would want to check for a supply if its only 2 1/2 years old
