The water pump's gone now🙄
Derbyshire
Elddis Accordo 105
since 2014
Another problem! Seems like everything is coming to the end of it's life at 6 years old 😒. Noticed the water pump light is on all the time, the pump isn't running but it's taking about 4 amps. If I open a tap it starts and works.
So it looks to me like the pump is stalling rather than switching off so it's a pressure switch problem. It's a whale watermaster pump. Anybody had any similar issues? Pic from last year...
I'll have a look later when we get back from shopping 🤔
I take it you are still in Spain, I'd replace it with a Sureflo pump you should be able to get one locally.
I'm surprised at you Richard, not carrying a spare.:giggle:
Thanks Lenny I've messaged them about one with JG fittings, looks like 12mm pipe not got me vernier calipers here though 😔
If its switched on and hydraulic locked it would pop the fuse and also pretty hot to touch.
Yes it must have been pretty hot when I first noticed in was on, was on like that for 20 mins or something ♨️😳 I expected some warm water to come out of the tap but none did 👍
Strip down time 😀 I'll have to start a Haynes manual 😂
Microswitch feels OK nice positive click click. Motor spindle feels a bit Errrrm 🤔very slightly not smooth and there's a very slight bit of noise as if the brushes are worn out or something. More screws to remove 😁
Oh that's helpful of them. It's a sealed motor 🙄
WD40 time if that doesn't work we're stuffed.
PS when I tried it last before stripping the motor wouldn't run, so it's the motor lost it's torque.
Ladies and Gentlemen! I declare myself a genius of the highest magnitude! 😎😁 With 3 squirts of WD40 lubrication into the motor casing (And 2 cans of Estrella Galicia to lubricate me😜) the pump is now reassembled and seems to be as good as new, alas I know it won't last. I'll get the Sureflow one when we get home 👍
And WD40 is a degreasant and good electrical isolater both of which are bad around an electric motor 😉
You use what you have around in an emergency, it's a sealed motor all he has done is free up a partly seized bearing just needs a drop of olive oil on it now as WD40 will dry out.
Or I need the optional extra 2 foot long WD40 aerosol tube so I can lube it from the wardrobe 🤣
4 days on and the pump is purring away like Rolls Royce, faster and smoother than it's sounded for months. Good old WD 😍
Ordered the sureflow off the linked eBay site, they are also sending 2 x 12mm GJ fittings (½"BSP thread by the way) and 1metre of blue pipe £64 all in 👍
Ordered the sureflow off the linked eBay site, they are also sending 2 x 12mm GJ fittings (½"BSP thread but the way) and 1metre of blue pipe £64 all in 👍
Did you get the inlet filter included?
Sorted 😁 I had to move the shelf a bit and make a bracket to hold the ballast upright.
I've also shortened the shelf by 2mm on each end so it doesn't touch the walls and mounted the shelf on 4 rubber pads, none of the screws are tightened up fully either. Just letting it dry out a bit after a stem elbow fitting blew out of the outlet 🙄 (binned it now). Had to adjust the pressure switch up a bit so it doesn't short cycle and got the signal wire back on it too. 😎
The old one lasted until we got home by the way 😁
