is the awning still in one or is it completely bent over the van?View attachment 177361 Storm blew through camping jungfrau in the lauterbrunnen valley. Pulled pegged awarning legs out of ground end bracket pulled through inner wall. Using tools from the campsite handy men managed to make temp fix. There's a dealer in Interlarken so hoping they can help. Outer wall looks ok, so hoping they can remove awarning straighten bracket and re seal until I get home next week. In mean time have made bigger bracket and put gaffer tape on awarning to bodywork to keep any rain outView attachment 177360
You can hardly blame the wind for that, they've put a bracket where there is no strength.
Brian, where is the strength in a motorhome? Apart from the chassis.
They are wafer thin insulated sandwich panels.
I stand corrected.I bow to your knowledge and experience.Ours has a wooden frame with insulation infill. Certain areas have heavier timber for load bearing, such as the awning and bike rack. Maybe not all do. Ours is far from wafer thin, maybe 40mm thick.
Thanks Ridgeway see what local dealer can do. Looking where it pulled through you could be right hilldweller
To honest I don't know the construction of your van, you need to see if there are frame timbers where you can make a bracket big enough to pick them up or of no timber frame then you need the biggest spreader you can fit.
Goodness knows what they do in the "new idea" all plastic sides so when it leaks it won't rot. [Any firm doing a proper job would build in hard points for an awning.
I understand that Hymer do
