Silver-Fox
Wet T shirts for me in the days.
Wet T rowel laid on my bare chest at night .
I had a vision then realised the wet t shirt was for you and now I feel deflated
Don't fight it big boy.I had a vision then realised the wet t shirt was for you and now I feel deflated![]()
the mind bogglesWet T shirts for me in the days.
We have a Fantastic vent works well but I believe the Maxxfan is better.Lovely and cool in here Jackd fantastic fan on pulling all the hot air out and drawing the cooler air in through the skylights
That’s what you get with quality Carthago!!
Save up a bit more then you can have one![]()
Only thing better would be aircon![]()
Coffee shops may also be included
Hi what unit did you have? we have the truma the large one works a treat even at 33degWe had 230V aircon on our last van. It was useless when the van was in full sun. First solution: buy a white van rather than a coloured one. Have you ever listened to coloured vans creaking as they heat up? Then close the window blinds on the sunny side as others have said. Our current van has two 12V roof fans. One is over the kitchen and the other over the rear bed. They don't make much noise on the lowest setting and are reversible so can blow air in or out depending on the conditions. They are normally used as extractors with a front side window slightly open to encourage a through draught. We have found them more effective than the air con. We also have an internal thermal blind covering the windscreen which makes a big difference keeping hot and cold air out.
I agree with all the above solutions plus we have a Transcool which we bought at one of the shows…plugs into 12v supply (or 220v adaptor supplied) …. Fill with water and the fan blows over a damp grill arrangement…cool air … doesn’t reduce the temperature in the van but the cool air is refreshingWet T shirts for me in the days.
France is still in the Northern Hemisphere the last time I checked, so shouldn't that be South West into the setting sun?Park facing North West (into the setting sun in summer)
No.France is still in the Northern Hemisphere the last time I checked, so shouldn't that be South West into the setting sun?![]()
Well, I stand corrected, you learn something new everyday, I assumed (always dangerous) that as France is north of the tropic of Cancer that the sun would rise and set to the south east and south west but it seems I assumed incorrectly. I'm going to get my compass out and check this evening thoughNo.
For quite a long time now, in the Northern Hemisphere in summer (May, June, July), the Sun rises in the northeast, peaks out slightly south of overhead point (lower in the south at higher latitude), and then sets in the North West.
Well, you would be correct to assume that in winterWell, I stand corrected, you learn something new everyday, I assumed (always dangerous) that as France is north of the tropic of Cancer that the sun would rise and set to the south east and south west but it seems I assumed incorrectly. I'm going to get my compass out and check this evening though![]()
Ahhhh thermodynamics, my favourite subject (seriously, I have an engineering degree)I can see that with the relatively uninsulated metal bodywork of a car or, putting it another way, an excellent conductor of heat, the colour is less significant. However, the white walls of our van are a sandwich containing a 45mm thick layer of polyurethane insulation. No creaks! I used to have a white boat with a black stripe down the side of the hull. On a sunny day the white hull hardly got warm while the black stripe got too hot to put your hand on.
I have one of these which works well.For a very compact simple aid to getting through the night try a usb computer fan in a wire cage laid on the mosquito mesh above the bed. Air in or out depending on which way up you put it. £15 on Amazon, quiet too.
That’s a good idea, never thought of that, thanks.A hot water bottle with ice cold water can help at night.
Tried smearing factor 50 on the front windscreen but it didn’t work…Park facing North West (into the setting sun in summer)
Park with a large tree to your left to protect from max power sun after mid day.
external sun screen for front window
blinds and awning to prevent direct sun on van.
Both opposing windows open full to allow the prevailing summer south westerly breeze through the van
Use a high flow extractor fan if no breeze to draw air right through the van.
As the sun goes down, use the fan to continually draw the lowering temperature outside air through the van
After sunset, close windows and use A/C for a couple of hours to bring the van temp right down to outside air temp for sleep.
A modern A/C unit will run on 200a/h of lithiums for about 3 hours.
That's reminded me of the Punkah Walla in it ain't half hot Mum, i just have to find someone to sit outside and pull the string nowLarge rectangular sheet of cardboard mounted on the ceiling - tassels on the lower edge with light string attached to the middle. If the other half waggles her toes a lot in the night - attach light string to her big toe. Make sure she sleeps on her back by telling her it stops wrinkles… Don’t be specific in what.
Ha - let’s assume someone actually tried that, it is correct to say that it wouldn’t workTried smearing factor 50 on the front windscreen but it didn’t work…
