Looking for a suitable battery clamp to attach the below cable which will be to my second leisure battery
Think he wants clamp to attach above cable to battery.You say 'clamp' but show a cable.
If it's a cable you're after, get one as thick as the others connected to the existing battery.
Yes that’s correct I have one of these which I suppose would do but would prefer something that more suitable just for attaching the ringThink he wants clamp to attach above cable to battery.
Because its a ring that's about your only choice.Yes that’s correct I have one of these which I suppose would do but would prefer something that more suitable just for attaching the ring View attachment 417708
Yes that is certainly an option , I just want to make sure the connections are 100% as I’m fitting a 1.5 kw inverterWhy not cut ring at end of cable off... strip insulation back and fit to clamp as it is supposed to be.
Then cut the ring off & use what you showed below.Yes that is certainly an option , I just want to make sure the connections are 100% as I’m fitting a 1.5 kw inverter
Yes I think that’s probably the way forwardThen cut the ring off & use what you showed below.
