Stuck in the mud
CDBaines
Cheshire
Apache 700
Since July 2020
Though I’d wash the Motorhome today, give it a mid Winter treat. All was well until I parked it back on the grass at the side of the drive. Now its stuck in the mud and my super Winter tyres are just not up to it. So, now I’m hoping for a dry couple of weeks and some hard frosts to help solidify the ground. I guess we’ve had lots of rain!
Any ideas on how to get it moving?
How old are you tyres ? Are they worn ?
where in Cheshire are you ?
bread trays under the drive wheels.
Or move it tonight while the ground is frozen
You need to befriend a tractor or 4X4 owner.
I always carry two strips of old good quality carpet with me, Hessian backed.
They have gotten me out of sticky situations.
In my view better than proprietary boards, as you can have long strips to keep you moving
If the water tanks are empty, filling them and the passenger seat might just give you enough traction.
Pull away in 2nd gear as well
Is it FWD or RWD, what make winter tyres are they? During winter always park on grass mats or similar on grass
Drop the pressure in the tyres of the drive wheels which vastly increases the grip if you can get it on boards. This is standard practice on 4x4 in the mud.
Lock it and wait until summer 👍
Hi.
It helps to clear a bit of the mud away from the front of both front and rear wheels ( If driving out ) before " Whatever " thats one less problem to overcome its like a choc.
Tea Bag
Took my chance this morning, place a couple of cut logs behind the tyre and rocked it back and forth in reverse until it finally, after 30 seconds or so gripped the logs and dragged itself out.
Thanks for all your interesting varied ideas and words of support.
Bread crates with sides ground off are lightweight but tough
Thanks for all your interesting varied ideas and words of support.View attachment 462084
Whose idea was that then?
Ian
In your own back garden.... I don't rate your chances on a rally field..😂😂😂😂😂
Although I’m out now thanks...tyres were brand new, but mud was so slimy and thick it made no difference. I guess they can only do so much?
Ian
Saw a version of it on You tube. Just so happens I have loads of wood cut into quarters so has a naturally sharp ridge. I was going to try the carpet next.
And that is why I will not have a FWD van.!!!
If that is where you will keep the van, this is not going to be the last time this happens. If you want to keep the grass, look to install plastic grids to reinforce the ground and allow the grass to grow through. Otherwise it is a dig out and add rubble/scalpings etc
about 20 years ago I had a similar strip of grass and the same issues. Temporarily I put down a layer of gravel and laid some second hand concrete paving slabs. It's still there although it is now more like scruffy crazy paving, which seriously annoys the wife, but never had a stuck wheel or mud since
Like most things, I intend to dig it out, but this is the first year and I just didn’t get around to it. I guess it’ll get done after the shower room.
Reactions: f6c
very much depends on each individual vehicle.
I never wanted FWD. After 3 Mercedes Sprinter motorhomes. Two with 4 wheels on one axle, always on winters. I was dreading our FWD FIAT. Preferring propulsion to traction.
It has been surprisingly good. Never got stuck even in deep snow.
But our FWD Motorhome has a lot of weight on the front axle.
