Can someone tell me what uses up less Gb streaming or downloading a film to watch later ?
When you stream content it will adapt to a bitrate that your internet & connected device can support. This is called Adaptive bitrate streaming.Can someone tell me what uses up less Gb streaming or downloading a film to watch later ?
PrimeThere is a quirk/bug with Netflix & Prime downloads is that if Wifi is connected to your device when you play a download it doesn't play the download it streams.
What makes it worse is that you can't connect to Netflix of Prime even to play your downloads without an internet connection. I've not tried it to see if it happens with a hard wired connection, my Android TV box I use hard wired at home but on Wifi in the van.
Two ways around the problem.
1. Open Netflix/Prime with the internet connection turned on, once the app has opened you can turn your Mifi off or disable data on your phone. Then any downloads will then play OK.
2. Open Netflix/Prime with the internet connection turned on, once the app has opened disable Wifi on the device, Android TV box/Firestick/Smart TV etc. Then any downloads will then play OK.
This method allows you to carry on browsing the web as well.
I assume The Ex-Gasman has found this out.
OK, I just verified that Prime works offline for downloads on iPad mini 4 (IOS 14.0 (sorry))Prime
<snip>
edit: I think I used Prime with the iPad mini 4 but definitely the Fire HD 10 is playing downloads as intended
I use an Android TV box so I don't know how it works on Apple on my box you can't even open the app without a connection.OK, I just verified that Prime works offline for downloads on iPad mini 4 (IOS 14.0 (sorry))
There was a popup when I launched the Prime APP about needing to enable "wifi to access data" but I chose "OK" & ignored that.
If it works in the house without the internet connection it will work in the van.You guys will know, will it work?
Before I go round the back of the home tele, & pull out wires to test the theory will my VM Tivo digital box, that has loads of stuff downloaded to it, work if I take it out to the van and play via HDMI lead from box to Avtex tele, without being connected to VM broadband.
I bet it wont somehow, but worth a punt on here first
LES
Works OK on Apple OS & Amazon's slim version of the Android OS so looks like you're unlucky & it's not lots of devices that can't work offline for downloaded media.I use an Android TV box so I don't know how it works on Apple on my box you can't even open the app without a connection.
Thanks for the heads up on trials.Lenny HB said:You can get a 30 day trial of Netflix just with an email address, had loads of trials with them by just using different emails.
Also if you know anyone else with an account you can connect 4 or 5 different devices at the same time. We use my daughters account, interesting she only pays ÂŁ2 a month in Thailand.
Just had a play, Prime now works without an Internet connection but Netflix doesn't.Works OK on Apple OS & Amazon's slim version of the Android OS so looks like you're unlucky & it's not lots of devices that can't work offline for downloaded media.
