- Feb 24, 2013
- 13,083
- 101,448
- Hymer S800
- not long enough
Disappointingly these words could probably be applied to far too many brand new products these days
But my experience of today related to a brand new Sterling Inverter chosen by me based on name and perceived quality
The products are pretty much unchanged as far as I can see for a good many years, I ordered mine to be fitted by Automate who have been brilliant in the choice, fitting and then resolving the problem, which was
When fitted, Rob (Automate) plugged in his socket tester to be shown reversed polarity nothing he could possibly have done having only connected 12V and fixing to a wall, so rang Sterling for support, which appeared to be sketchy at best, bordering on useless
So Rob decided to remove the front of the inverter I was all for sending it back, but Rob wanted to try and solve the problem, first thing was the earth wire either fell out of its connection or more likely had never been connected, closely followed by the neutral wire, but the live connection still in place confirmed it was wired correctly. Reconnected both above and checked live, still shows reverse polarity
rang Sterling again but gained nothing, Rob asked about the possibility of something being wired wrong and was told if it was it would need to be de and resoldered, which then confirmed they were winging it
Rob looked a little further inside and immediately saw the wires feeding both outlet sockets were reversed, luckily though were both push on terminals, so once found quickly resolved
How on earth though can such things happen, surely some kind of test is carried out before despatch
Top marks and thanks again to Rob from Automate http://www.automateuk.com/ I will look to add to or create a review in a bit
I don't suppose reverse polarity would have done us much harm, or hopefully even anything we plugged in, although thinking about it if we use the 2 pin option with or without an adaptor it is pretty much 50/50 if that become reversed I guess, our euro adaptor certainly has nothing to stop it going it either way up
