Step for cab door ? (1 Viewer)
Jul 29, 2013
9,076
18,656
Salisbury
Hymer B678DL A class
since 2011
I did enquire about having one fitted by a Hymer dealer they said there was a lot of work required as the chassis needed to be cut and quoted a ridiculous sum needless to say never had it done and not found a solution other than a hop up as suggested by others.
Apr 8, 2015
321
292
Lincoln
coachbuilt
15 years
Same problem same solution. £5.00 step available all over. Kept in Cab door pulled up with string from the cab seat.
wanderer
643
769
huntingdon
a class Arto
since 2008
Is this the Rolls Royce of motorhome steps
Feb 16, 2013
19,772
52,179
uttoxeter
ambulance conversion
50 years
Minxy
32,700
66,734
E Yorks
Carthago Compactline
For those who use a step on a bit of string to climb in with ... how do you do the reverse to get out? If you open out the step won't it just fold back up as you lower it?
Jul 29, 2013
9,076
18,656
Salisbury
since 2011
That looks like a solid bit of kit must weigh quite a bit?
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
As for the plastic step, I remembered others who have used this method but thought it might be a bit too 'low tech' (or lower class) for 'A-class owners! :D
It works for me but then I am nearly careful enough to be mistaken for a Scot or a Yorkshire person. Cost to date €6 (that's €5.98 for the folding step from Electro Depot in Brive + €0.02 for the string already in stock). Further investment on R&D is anticipated, may have to seek out long life strings. As for only being a temp solution, fine, I'll buy another.
Sadly this won't work in the US market as the step is only suitable up to 130kgs (might be ok for pre-school I suppose)
Not if you have 2 strings, each one looped through 2 corners. How do I get a spot on Dragon's Den?
