The Green's
Can you use stainless screws into aluminium brackets, such as when mounting your solar panels onto some aluminium angle brackets? Does the risk of bimetallic corrosion outweigh the benefits of your screws not rusting?
<Broken link removed>
Stainless steel fasteners in aluminium plates or sheets are normally considered safe, whereas aluminium rivets or bolts holding stainless steel parts together is an unwise combination, as there is a practical risk of corrosion.
So from reading that it seems that using stainless self tappers to fix you solar panels to your aluminum angle brackets is fine.
Just don't use your drill/impact driver with those stainless steel fixings, they may as well be made of aluminum the way they snap!
I was recently "reminded" that I do have hand screwdrivers too
