It's probably printed on the sides which we cannot see and I cannot even magnify the picture? Need more info!My battery seems to have no ID. Anyone any idea what it is? As you can see it's a 180 Ah AGM, but that is all I know.....
Nah, nothing on the sides. You have as much info as I do..... It's in a Pilote if that helps, and I think it's the orginal.......It's probably printed on the sides which we cannot see and I cannot even magnify the picture? Need more info!
As far as I know, there's not many 180 Ah batteries?
Well, I think the jury is still out on the performance of this particular AGM battery. I have my suspicions, but I'm still gathering evidence for a conviction...... I did wonder about those terminals. What's the problem with those, Lenny HB ?Not a clue on that one but it has those horrible pressed steel quick release terminals they need to go in the bin with the AGM battery.
I think you will find under the covers they are pressed steel, not very good for conducting electricity, can't beat good old fashioned solid brass ones.Well, I think the jury is still out on the performance of this particular AGM battery. I have my suspicions, but I'm still gathering evidence for a conviction...... I did wonder about those terminals. What's the problem with those, Lenny HB ?
What more do you need to know? Is it duff or are you just curious?My battery seems to have no ID. Anyone any idea what it is? As you can see it's a 180 Ah AGM, but that is all I know.....
Yeah, that seems to be what happens. I guess I'll know more once I've fitted my new Victron BMV 712. Cheers for that thought.Yes, the off-load voltage is O.K. but the battery can still be knackered. The voltage may drop considerably as soon as a load is applied.
Ah, that looks like a smart way to find out what is going on. It'll take some setting up though, as the van is in storage. So I need a 2000W load?Best way to test it:
First charge the battery fully and leave it to settle for an hour then:-
For example if it's a 100a/h battery load it with a 5 amp load and run for 5 hours, this will represent a 25% discharge. (adjust load/time to suit the size of the battery) For your 180ah battery the C20 rate would be a 9 amp load.
Disconnect the load and leave to stand for at least 30 min then measure the voltage.
Repeat the test and you will have discharged the battery to 50%.
You can repeat again then it will be 75% discharged.
That's interesting, but I can't imagine a French made van would have an American battery. Unless the previous owner was into long range sourcing and swapped it.It looks very much like the battery that came with my ambulance, made in America, it was flat when it came and I couldn't get another one like it so swapped it for two ordinary 100 amps.
My ambulance is frenchThat's interesting, but I can't imagine a French made van would have an American battery. Unless the previous owner was into long range sourcing and swapped it.
That would kill the battery, 2000 watts is 166 amps.Ah, that looks like a smart way to find out what is going on. It'll take some setting up though, as the van is in storage. So I need a 2000W load?
What a muppet! I calculated using mains voltage not 12 V........... Cheers.That would kill the battery, 2000 watts is 166 amps.
You need approx 110 watts.
I think They are sold as Xplorer batteries by Alpha batteriesWow! You could be right, it looks very similar. I will pursue that. Thanks.
Fantastic! Thanks very much. I will try to get some sort of spec out of them.I think They are sold as Xplorer batteries by Alpha batteries
Buy Car Batteries & Leisure Batteries Online - Express Next Day Delivery - Alpha Batteries
Order your next Car Battery or Leisure Battery online from Alpha Batteries today! We stock a wide range of Batteries ready for Express UK Next Day Delivery.www.alpha-batteries.co.uk
I'm struggling to think how I would get a 110W 12V load..... I expect it's obvious.That would kill the battery, 2000 watts is 166 amps.
Headlight bulbs?I'm struggling to think how I would get a 110W 12V load..... I expect it's obvious.
