ambulancekidd
- Sep 23, 2014
- 10,365
- 28,388
- Swift Kon-Tiki 640
- Since 1964 Gosh that makes me feel old.
Our elderly motorhome is in the process of being dragged kicking & screaming into the 21 century & it was the turn of the radio.
The old SONY radio/CD player was woeful, speakers kept dropping in & out & it took a hard whack on the dash board to get them working again.
So I knew it'd be a mission to get it all working properly.
I bought one of these new fangled radio/DAB/USB thingies then bit the bullet to get stuck in fitting it.
Hauled the old unit out & saw the magnitude of the task I'd set myself.
Taped joints which were simply wound together & were everywhere, it was a disaster zone.
Battery isolated, multimeter in hand I snipped most of what was there & started again, scary stuff.
I tracked down all four of the speaker cables, they'd been wrapped around other wires etc & were in a shocking mess (pun intended).
Next was the the power input which had been spliced into the cigarette lighter cable with a lump of very loose tape, both the feeds were drawn from one permanently live source. a lazy trick if ever I saw one.
There was no earth wire, the bodge merchant had just allowed the aerial earth to do the job, not good.
I always make any cable joins with solder & heat shrink sleeves, joins in cable should be avoided where possible but security & proper insulation is not only necessary but essential.
The only joins I put in were to join the motorhomes wiring to the standard plugs on the back of the new radio.
Now a question for everyone; Why when you've spend a small fortune buying a motorhome or a car, would you do the work in such a dangerous way that you might cause an electrical fire?
I've come across this type of bodge work so very often, it's frightening. I'm not an electrician of any sort, but it costs pennies to get the correct kit & the old Ducato is ridiculously simple to fit auxiliary equipment to.
The fuse box unscrews & under there are plenty of spare spade terminals, just take the time to select the correct fuse rating for your chosen gadgets & its job done.
Carefully feed the wires to the gadget & cable tie them to existing wires making sure nothing can chafe them.
I should have taken a before & after set of photo's, but I have taken a few of the connections & the new radio in place to show how it should be done, please remember to leave enough cable to be able to work on things in future.
The radio head unit itself is simply a cheapo Chinese job @ £28, but it appears to work very well indeed, it'll remain to be seen how well it does long term.
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=324224090730
