OK yes its no big deal. Just wanted to know if it was just me.Tend to pull the plug out of the unit when on ehu saves the annoying beeps when it reboots no big deal
Good piece of tech haven’t worked out how to change to kmh but then again not really played with it the instructions translated from Chinese are challenging ???OK yes its no big deal. Just wanted to know if it was just me.
Otherwise a great improvement because the standard speedo is ridiculous.
The Can bus wakes up at preset interval and checks for activity even if it does not get a wake up signal like when you unlock the doors, if it receives no activity on the bus it goes back to sleep after about 10 to 20 mins, the additional speedos are read only for the most part so do not stop the can bus going back to sleep.Do either of you peeps with the hud devices from ebay have an issue with them when on 240v hook up?
I bought one and it works fine until I plug into the mains when it goes through a continual reboot process. I suspect the obd port isnt turning off like it does normally when not on charge and this is confusing the hud.
