Spark generator needed for Smev Oven.
68c
Southampton
2001 Pilote 270
Since 2004
Can anyone help me with getting a replacement spark generator for my Smev oven.
Oven Smev OF311FGT
Spark Generator ITALQUARTZ Srl H21/09/02/12-1Hz
The spark generator runs on 12 volt and has two outputs, oven and grill. I have searched the web but only found one in Poland from a supplier who will not post to the UK.
It seems to me any 12v spark generator would do however I can only find units with more than two outlets. Does anyone know if it is OK to just two of the outputs from a multi output unit.
Oven Smev OF311FGT
You can use a 4 wire outlet just run the other 2 to earth (cooker body)
Reactions: 68c
I am not an expert but would think any 12v camper spark generator would work. I thought mine was faulty but it was just a loose connection on cooker as they do suffer expansion and contraction forces due to heat and can come loose.
Reactions: 68c
Bit cold out there now but prompted by your suggestion i will make sure there is an earth connection to the cooker body to complete the hi-tension circuit. I have confirmed 12v at the unit when selected.
Oven Smev OF311FGT
Hi, did you ever manage to get a replacement part ir find a differentpart that worked, I also need the same part.
