- Oct 30, 2016
- 1,875
- 3,923
- Hymer BMC t780
- On 4th van so not a total newbie....
For a long time I have been unhappy with the output of my panels, factory fitted is 120w, and the dealers added 2x150w zamp panels and a zamp pwm controller.
Recently I tried covering each panel and disconnecting, one of the panels is proving no power at all, although testing is proving 24v, so seems alive but why no power?
I have replaced the controller with a victron 100/30 unit, which is ahowing the output at 14-15amps, but the vans battery meter only shows about 8-9amps (I ran the battery down to about 70%) seems like about 40%loss? Initially I had assumed it was going through the vans charger which was limiting the charge, but it is connected direct to the battery.
Finally the attached photo shows how the panel is fixed to the fixings any idea what these are called so I can get a bit, rather than drill out, if I need to remove to access the underside?
