Solar Prep?.. means?
Mile Oak, Tamworth
McLouis
Since 2008
My 2012 Chausson is described as being “Solar Prepared”
does any one know what this actually means ??
( obviously I am looking to self fit a solar) ?
cheers
Clemmo
It will be pre-wired for a solar panel.
Where the wiring will be, and to what extent, is anyone's guess
Looked into this on my 2018 Chausson.
Wiring was hidden behind a secured panel however the general consensus was not to bother as the wiring wasnt up to much & wired through control unit would limit panel size.
Dealer confirmed this as did other funsters.
If you need solar wire direct through it's own controller?
Hope that helps
Yes.. that helps.
I won’t bother hunting.. I’ll just put Solar in as an addition.
Thanks for your support
Clemmo
If it is pre-wired eg, a Malibu van there will be 2 solar wires not connected near the leisure battery with + and - on them, the rest of the solar cables will be hidden and will emerge again under the fridge.
Really what they mean is 1/2 pre-wired ready to fit a solar panel.
If it is pre-wired, does that in any way mean it is standard equipment? After all the insurance 'modified' vehicle term is only partly true.
