Solar Panel
Glasgow
Bailly Autograph 730
Since 2016
Help please looking to install a solar panel on my Bailey 730 Motorhome, thinking about 100/130 any help re choice / make etc would be gratefully received
Hi, a good place to start is to select a suitable spot on the roof and measure what space you have. then IMHO fit the biggest wattage panel you can into that space allowing for brackets and the roof gland.
i have a single 140watt. but it really depends on your style of motorhomeing..
also this is worth a read.
So I bought a solar panel from Sunstore and had it fitted by my mechanic, the display shows a flashing H and nothing else, help
I am not that knowledgeable on Controllers but I would imagine the first question will be what controller are you using
I am fairly sure the leisure battery was connected after the SP and then the cab battery was connected
Some controller don't know which battery or type you have connected so it will drop into fault mode.
Try reconnecting the solar panel
He has done it wrong then, don't leave it connected it may :swear2: your battery if it has set itself to 24v.
You said the display is flashing H the controller you said you have doesn't have a display.
