Yep it’s on the roof and I can see a coil of wire underneath . But can’t see where it enters the MH (if it does at at all)Are you saying it's already mounted on the roof & the wiring is in place. If so you will need a solar regulator between the panel and the battery. Best solar regulators are the MPPT type like Votronic & Victron.
May need to get a cable entry box and work out how you are going to route the cables. Then get brave and drill a hole in the roof.Yep it’s on the roof and I can see a coil of wire underneath . But can’t see where it enters the MH (if it does at at all)
See where the end of the wire goes it may already be plugged in, also check in cupboards for the controller if there is one, did they charge you for it?
I’ll give it a go thanksTurn everything off in there in the morning and disconnect the electric, wait till midday. If the habitation battery voltage is above 12.7 and ideally above 13 volts this time of year it’s wired up!
When I put the solar panels on previous MHs I put the controller next to the existing Electroblock so see if yours is near it, other than that its a case of hide and seek!Well the mystery deepens . I’m pretty sure the cable comes into the cab into one of the cupboards as one of you guys said and I’ve found an instruction book for a solar power controller (no brand name) with a picture on it .... just haven’t been able to find it .
I opted not to have a solar panel and didn’t pay for one sooooooo I may have just lucked in . I’ll look at the control panel on a sunny day , if we ever get one .
