Just spent an age searching back through previous threads and this is what I intend doing based on that.
New Van has an agm 100amp battery and a compressor fridge.
Use current battery until it dies in 12-18 months. Then replace with 2 gels or a single lithium.
Intend putting 3x 100amp semi flexable panels up top if I can find the space.
Votronic mp 350 duo charge controller connected direct to hab battery which will also give a 1amp trickle to the vehicle battery(lead acid).
Also found a victron cyrix-ct which it seems enables excess charge generated from solar or alternator to be directed to batteries requiring charge once primary battery is at correct level.
Constructive comments please.
