Drwolly
- Mar 19, 2021
- 3
- 0
- Team Roller 500
- New to MH but had caravans for 15 years
Hi all
I have read through the winter months you may not get enough charge from solar to keep your battery topped up due to the lack of sun etc but I have noticed I don’t appear to get any benefit from my solar panel. I only purchased the mh a couple of months ago and have been checking on the status of the batteries, the leisure battery is 110ah and is the only battery connected to the solar.
There was an issue on the connector on the roof which I repaired and the panel was showing 21.1v on meter, it also shows the same on the control unit but never any amps, so wondering is the controller shot?
Also one other question, if your main battery ever went to flat to start the engine, can you jump lead from the leisure battery to assist in starting? Bearing in mind there is dual charge system but can isolate the leisure battery from this.
