Solar Cable (1 Viewer)
Jul 26, 2015
297
199
Devon
Hymer
HI all.
My solar controller has only got one battery outlet on it for my leisure batteries but i also need to charge my vehicle battery so i have ordered a new controller with batt 1 and batt 2. My question is what size cable do i need to go from the controller to my vehicle battery.
Many thanks:xThumb:
andy63
4,672
15,018
south shields
since 1990
4 or 6mm square cable should do.. most panels come with the 4mm square just in case you need something to compare with..
Andy.
Jul 12, 2013
3,883
5,290
The City of Henlow
Adria Supreme
Since 1980
Large enough to cope with the amperage generated by your solar panel, which in the grand run of things, is not great. I am sure a technical boffin will be able to give a more precise cable size.
Two on Tour
10,406
51,586
Elddis Autoquest 175
You do not need to use the double insulated type cable that runs from the solar panel to the controller you can use a good quality single insulated copper cable for the run to the battery from the controller.
I bought mine from AES
https://www.autoelectricsupplies.co.uk/product/70/category/114
