We about to spend a week at a rally using only 100w of solar to supply our leisure battery, and the starter battery via a Battery Master.
have no idea how much power we will need so plan to keep electrical usage to a minimum.
The leisure battery is an AGM type but I do have a spare wet cell leisure battery at home which I may stick in the boot of the toad just in case.
Q1. Can I just swap an AGM and wet cell as regards the on-board charger, solar controller and the engine charge from the alternator? Are they interchangeable?
Q2. If I did want to swap in the wet cell battery would I need to disable anything on the solar side whilst I did it? I realise I would have to be careful about shorting out the leads but will I cook the solar controller or main EBL if I just disconnected the AGM and connected the wet cell?
TIA.
TIA.
