Soft wood under Hymer garage floor (1 Viewer)
Robert Harkness
5
Hi, has anyone encountered rot under a Hymer garage floor? If so, how did you deal with it, or who did you entrust with the repair?
Thanks in hope and anticipation.
Rob
Nov 17, 2012
1,929
2,643
WEST SUSSEX
HYMER B SL 674
SINCE 2005
What model/year and specifically where? And where do you think it's coming from? And what part of the country are you in?
scotjimland
1,436
5,198
UK
Timberland
Jun 30, 2011
7,019
18,891
Barnard Castle, UK
Concorde Concerto
Its a big problem on some vans, 1997 -2006 are the worst affected I have found.
They should have used GRP to start with.
It was meant to be an area where owners checked every year and made good any rot etc.
In reality 99% of owners never touched or even looked at the area, out of sight out of mind.
I have found the models with transverse bed over large garage are the worst affected, seem to be more exposed than the models with the habitation door at the rear, ie 640 Starline.
It then depended on where the van was stored(damp, windy climate), if it was driven regularly in driving rain, whether it had mud flaps as they offer some protection.
I have put my fingers through quite a lot, the rot has been extensive, some even stick a strip/area of wood on top to try and cover it up(bodge job).
If it gets extensive it can even extend to the area coming up the sidewall(below the garage skirt) and also at the rear area. I have seen areas of garage floors collapse when it gets bad.
Don't ignore it or cover it up.
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
I discovered it on my 1999 B534 just recently, and found the thread by @scotjimland as above, and repaired it in exactly the same way with the same products. And I'll take this opportunity to say thanks to Jim for posting about it.
R
Robert Harkness
5
Hi, Scotjimland
Thank you for that information. I looked at the thread, and there are a few helpful suggestions. Can you add anything, like a step by step of what you did? Sorry to be dense, but the thought of tackling the job is a bit daunting.
R
Robert Harkness
5
Hi, Pandas
It's a B644 as per Scotjimland's post, in exactly the same location - under the garage floor - and we are currently in the Oxford area.
scotjimland
1,436
5,198
UK
Timberland
Hi, Scotjimland
Hi .. it's daunting but not that difficult.. provided the rot hasn't penetrated too deep or too wide an area.. mine was about 9 x 12inches and about half the depth of the plywood..
first thing I did was dig out as much of the soft wood as possible.. using a sharp wood chisel.. was quite ruthless.. then dried it using a hot air gun.. it's important to get it as dry as possible.
then applied two coats of Ronseal Wood rot hardener.. let that dry until it was hard
next day I filled with the Ronseal two part epoxy wood filler.. you have to work quickly, it 'goes off' quite quick.. like fibre glass resin does.
when that was hard I sanded it down, then then painted Hammerite underbody sealer.. two coats ..
hope that helps.. any other questions just ask..
R
Robert Harkness
5
Hi Scotjimland,
Sorry, just realised there is another page to the thread - I'll go and read that!!
Chris
20,825
258,514
None
10 years
I thought German vans didn’t leak like sieves:rolleyes:
scotjimland
1,436
5,198
UK
Timberland
water damage on the underside of the floor, they said it was due to salt on UK roads.. which they don't use in Germany .. ;)
they now use GRP for the floors .. sorted .. (y)
Chris
20,825
258,514
None
10 years
Germans are liars Jim.
They also said they wouldn’t invade Poland if you remember:Smile:
Northernraider
25,866
152,465
On the sofa ....
Hymer 654
On and off since 95
I found one very small soft patch on the underside floor on my hymer.
Strange thing is it isn't near the wheels it's at the very back outer corner.
I scraped out the soft bit , filled it and have painted the underside floor with hammerite.
It's gloss so the water doesn't penetrate it now. The rest of the floor is solid but I'll keep an eye on it. I had considered covering it with a thin sheet of plastic but I think the paint should do it.
Jun 30, 2011
7,019
18,891
Barnard Castle, UK
Concorde Concerto
Not sure about plastic Tam, that's what Swift used to do and it was a disaster I recall, timber needs to dry out and breathe.
scotjimland
1,436
5,198
UK
Timberland
Just my understanding, not a timber expert..
the floor is made of plywood.. it doesn't need to "breathe" like natural timber.. it should be stable and not expand, contract or warp but requires sealing to prevent water ingress and rot .. clearly the Hymer under-seal that was applied didn't do the job of protecting from salty road spray ..
Northernraider
25,866
152,465
On the sofa ....
Hymer 654
On and off since 95
Aye in the end I didn't do it Paul but I thought long term it might have stopped any further damage. But to be fair the van is 14 years old and I found one small patch approx 4 inch square that was a little soft on the underside.
So wasn't a big drama.
Painted the underfloor on both sides of the van from rear wheels to towbar and I'll keep an eye on it
Jun 30, 2011
7,019
18,891
Barnard Castle, UK
Concorde Concerto
Not sure about that at all, once moisture gets in anything containing timber, the moisture needs to get out, which is prevented by the black underseal. It's a difficult one Jim I have heard points for and against what to do for the best.
scotjimland
1,436
5,198
UK
Timberland
yes, I agree..
best course of action would be to cut out and replace.. but that's a big job.. the repair I did should be good for years ..
it's like filling a car .. best would be a new panel.
Northernraider
25,866
152,465
On the sofa ....
Hymer 654
On and off since 95
I think if you dry it out first and then seal it there shouldn't be any moisture in the wood.
It's certainly covered on the inner side as mine has laminate inside the garage same as the internal floor.
By the looks of mine it actually looked a little burnt like someone had tried to dry the patch out with a blow torch or something.
Jan 31, 2016
1,865
3,208
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
Good set of mud flaps work wonders. Mine, Fiat Maxi chassis Hymer B544 has lorry type flaps fitted, the van is 6 years old and looks as good as new underneath.
Gloss oil based paint is not the best to use as it will hold any damp in, not letting it out and eventually breaking down. A very good quality water based paint is far superior to oil based gloss.
This
https://www.rawlinspaints.com/home/...ood-finishes/1396-jotun-butinox-futura-3.html
is by far, a very good paint finish, 2 or 3 coats will last a lot longer than any oil based paint. I painted my timber garage door 8 years ago,and it's still in good condition despite not having been touched since.
