How many snow chains would I need travelling through France down into Spain in January, and will need any for towing a trailer with small car on it
One set of two (unless 4WD) you only need them of the driven wheels.
yes in reality I'd put them on all four as no good fwd & the back takes the front out.
rear wheel drive I would be happier only on the back only.
When I was doing ski work with my coach and ONLY had 2, when on REALLY icy roads, the trick was to put the chains on the wheels FURTHEST from the curb, front AND back.
Beside, or in the curb there is usually enough dirt and gravel to give those wheels SOME grip and then SLOWLY move forward or the flailing chains, if they become slack, can rip the steering off!
Yep chains are required if you don't have winter tyres in I think 47 departments from the 1st Nov this year.Have the rules changed? I've never needed them before to pass through on main roads.
Just been and checked, got the snowflake so happy days, highest I'm likely to get is Somport Tunnel anywayYep chains are required if you don't have winter tyres in I think 47 departments from the 1st Nov this year.
They did announce last week they wouldn't prosecute offenders for the first year.
Only if you are Ari Vaatenaan . It is the same as putting the new tyres on the front .they grip, back goes & spins it out. Same with chains.If it's FWD you don't need any on the rear....even if the rear slides sideways it will continue forwards and eventually pull the rear back in line.
As long as it is open when you get there & you don't have to go over the top.Just been and checked, got the snowflake so happy days, highest I'm likely to get is Somport Tunnel anyway
Only if you drive like a fecking idiot, then you deserve to crash painfully.Only if you are Ari Vaatenaan . It is the same as putting the new tyres on the front .they grip, back goes & spins it out. Same with chains.
Don't worry I will be checking the reports long before I get there, no way am I going over the top in December. Other options are available as they sayOnly if you are Ari Vaatenaan . It is the same as putting the new tyres on the front .they grip, back goes & spins it out. Same with chains.
December !! I had to go over the top in July 2014. Fog was so thick I had to look out the side window for the remains of the white line. Hadn't done that for 40 years. What usually adds 30 minutes & is a nice route on a sunny day took best part of 2,5 hours.Don't worry I will be checking the reports long before I get there, no way am I going over the top in December. Other options are available as they say
Snow chains are only by law in certain areas please see link to french goverment site
Nouveaux équipements hivernaux
Entre le 1er novembre et le 31 mars, il est obligatoire d'équiper son véhicule en pneus hiver ou de détenir des chaînes ou chaussettes à neige, dans certaines communes des massifs montagneux (Alpes, Corse, Massif central, massif jurassien, Pyrénées, massif vosgien). 34 départements sont soumis à...www.securite-routiere.gouv.fr
Thanks thats pretty much what I thought.Snow chains are only by law in certain areas please see link to french goverment site
