Sikaflex (1 Viewer)
Jan 10, 2011
75
20
South Coast
Frankia i800 A Class
Morning all, which sikaflex is recommended for bonding solar panel mounts to the motorhome roof, looking at either291i or 292i.
Also what is the recommended surface preparation for a GRP roof
Many thanks
Mike
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
Think I used sikaflex 512 (there was a pic of a caravan on it anyway)
I wiped the roof with meths and then screwed down through the lot. My roof is aluminium skin though.
Jul 29, 2013
9,075
18,621
Salisbury
Hymer B678DL A class
I wouldn’t screw down through the roof the less holes the better I have found Stixall to be very good and cheaper than Sikaflex.(y)(y)(y)
2,380
10,350
Neither ..
This is the instructions from Alden
I followed them to fix an Alden AS4 auto dish , a lot heaver than a solar panel.. no problems
Sika 252 for fixing sat dish or solar panels.
Glueing the external unit
  1. Use a pencil to mark the place of the unit on the roof.
  2. Sand the roof surface with sandpaper.
  3. Clean each surface with a thinner.
  4. Spread Sika-Aktivator on the sanded surface.
    Leave to dry for 15 to 20 minutes.
  5. Glue generously the base of the unit with SikaFlex 252 then press slightly on the unit. Layer of glue: ± 3 mm.
  1. To accelerate the polymerisation, spray a little water on the visible parts of the glue.
Leave to dry for 24 hours.
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
Neither ..
I'm not saying they're wrong, but why is there a picture of a motorhome on Sikaflex 512?
Perhaps it's for sealing windows or something else :eek: anyway it's immovable now it's cured.
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
Googling further... I think they're mostly the same product with a few different additives in.
2,380
10,350
the photo of a motorhome doesn't tell you what it's specific application is ,
each Sika product has a different application.. adhesive, sealer, marine, etc..
Alden supply Sika 252 + Akitvator and Instructions with the auto dish kit.
my dish has been on three years, and was still there when I sold the van
Oct 29, 2016
4,509
52,946
Surrey
Carthago C Tourer
Nearly ready to fit my solar panels and cable entry box to our new moho.
I have the Sikaflex 512 but dont have the activator/cleaning stuff. Is it really needed?, from what I have read thus far on here, provided that I prepare the surface with some wet & dry where the brackets are being located, wipe clean ect, then the stuff sticks like you know what to a blanket.
Am I wrong?, I sure wont be screwing the brackets to the roof though, too scared on that one :eek:
Les
Silver-Fox
9,278
29,175
Cheltenham Spa
Rapido
im a not so newbie
Personally I would use panel wipe for cleaning any area to take adhesive.
It doesn't leave any kind of residue behind.
Oct 29, 2016
4,509
52,946
Surrey
Carthago C Tourer
Thanks for that, can you give me an idea of what "panel Wipes" you are referring to.
I have screen wipes but I guess you are thinking of something different, Just wish I still had my aerosol can of Switch Cleaner, that cleaned everything in the old days.
Les
Silver-Fox
9,278
29,175
Cheltenham Spa
Rapido
im a not so newbie
It might be worth going to a local body repair shop with a small container and ask if you can have a splash of panel wipe. Bung them a couple of quid for a coffee and jobs a good un.
Its the fluid they use prior to painting so you cant afford to leave any chemicals on the panels.
Shame your not closer as I tend to buy it in 5l cans when I'm doing a car polish.
Or buy switch cleaner as you say :)
Simon Richardson
212
139
East bound & down.
Carthago C Tourer 150 I
Full timing since Dec 2017
I used 512 for my Dish as per Maxviews instructions. It's that sticky you could clean your roof with a Baby Wipe and it would still stick! (y)
Oct 29, 2016
4,509
52,946
Surrey
Carthago C Tourer
Thanks Guys for the advice.
Les
11,957
16,573
Switch cleaner (most varieties) contains corrosion inhibitors and lubricant. I wouldn't advise using it to degrease / de-wax.
andy63
4,672
15,018
south shields
since 1990
If you dont have panel wipe as mentioned already , then i find a final wipe down with meths cleans the area up well enough..
On the sikaflex question... again i find any of the brands of pu adhesive /sealant does the job just as well , often at a fraction of the price of sikaflex
Andy
Oct 29, 2016
4,509
52,946
Surrey
Carthago C Tourer
Thanks again Guys jobs a good un.
Halfords do packs of panel wipes for £1.40:)
Les
romany
714
2,082
Oxfordshire
Wildax aurura xl
since 2014 camping since1968
Another vote for Stixall here used it to stick an awning rail to the bottom of my fiama awning (easier for drive away awning) and that is still holding two years later despite having the awning up during some fairly strong winds.
