Shurflow replaced submersible pump … (2 Viewers)
Aug 12, 2023
15
Adamo
2SGBRB
Aug 12, 2023
15
Adamo
I have replaced whale submersible pump with a shurflow. Everything is working fine. However my control panel shows pump running. I have bypassed the pressure switch ( see photos) do I need to do something with the pressure switch wires…. Any assistance please…. So chuffed that I managed this by myself… Baileys Motorhome
654
2,564
North Devon
Autosleeper Kingham
Watching for replies to this before l start to replace the same
bobandjanie
8,183
15,870
Javea, Spain
Pilote V600g
Shurflo pumps have a pressure switch built in, we have been thinking about doing the same, and also have whale system. 🤔 I think Lenny HB has done it. 😁 Bob.
291
2,587
Fareham
Since 2017
On my sureflo the red from the motor top connects to the top spade at the pump. The pump running light is fed from the bottom spade connector on the pump. Is yours the same?
54,411
154,560
I replaced a Reich Submersible pump on my Hymer with a Shureflo, no existing pressure switch.
Strange control panel that shows the pump is running only Bailey could come up with that. I suppose it's a caravan control panel & the pump would be in a bucket outside. :rofl:
Disconnect the wires from the switch if that doesn't work connect he two wires together.
654
2,564
North Devon
Autosleeper Kingham
That solenoid is probably to do with the silly Whale filling system.
Think so, l've never used the Whale in 8 years since l had the van.
I'm just trying to understand which pipe(s) section flows and where l intervene with the new pump if that makes sense.
654
2,564
North Devon
Autosleeper Kingham
Me again sorry -
Re:fitting a replacement Sureflow pump (AS Kingham)
Regarding the two electric cables from pump to---power and negative-
The red power cable, can I use the now redundant pressure switch cable and connect to the red/live wire from the new pump. If so will l also need an inline fuse holder?
Regarding the black negative cable from the new pump, can l fix it to the metal frame of the nearby bench seat or do l have to run that to the battery negative?
54,411
154,560
Me again sorry -
Should be fused in your distribution unit.
As long as the seat base is a good earth it should be OK connecting the negative to that.
