SHURFLO Trail King (LS204) mysterious overflow pipe help please.
Jun 22, 2014
606
837
Great Totham
Adria Twin 640 SGX
Since 2015
Hi,
When I run the pump all is fine but as soon as it stops I get a good run of water coming out of some kinda overflow pipe from under the van, Its not from the drain off pipe, there are a group of three and its coming from that. The tank can be 1/2 full and it will still happen. Van is a Dethleffs Globetrotter.
Anyone know what might be the cause of this?
Thanks.
Cheers Tony,
I have the frost dump style and I have just triggered it, run for a bit and reset it. It seems to have stopped now. I don't see the connection from running the pump, it stopping and then it coning out the heater frost dump though.
the smaller pipe is usually the elbow on the top of the water heater it has a air admittance valve incorperated to allow air to enter when you drain via the other valve
