Mike Gibbs
The spluttering started some time ago and has been getting worse. So I took the pump home, took it to bits, cleaned lots of sludge out of it and checked all of the parts for wear or cracks and I found none although the beige coloured diaphragm had black stains which I could not remove. I put it back together and tested it (at home) without the filter and it still splutters.
I found that Hozelock tap adapters with the converter for small taps fits the pump's inlet and outlet perfectly so I'm fairly sure that the pipework isn't letting air in.
So, my question is: where on earth does the air get in?
Thanks in advance,
Mike.
Thanks in advance,
Mike.
