Hi I have just installed one of these water restrictors http://www.ebay.co.uk/itm/111106954...49&var=410187272032&ssPageName=STRK:MEBIDX:IT
My pump is a Shurflo SUK - 0227 30 psi 7 ltr
My question is normally when you turn on the tap the pump starts then when you turn off the tap the pump continues until the pressure is build up, then the pump stops.
Well now with this restrictor fitted then water flow is reduced
As intended , but as the pressure builds up in the line when the tap is running as the flow is being restricted the pump starts and stops as the pressure builds up then it's released.
So my QUESTION is will the pump starting and stoping more be detrimental to the pump ?
