Service coupon expired ???
Earby, Lancashire, UK
In between
started Oct. 2016
My Peugeot powered motorhome now shows "service coupon expired " when I start it.
Anybody there can confirm what I think I'm that the service time was not reset at the last service, and how do I reset same?
Phil
I think it means your due for a service or if you've just had one, they have not reset the service coupons, you will need to take it back to them or buy the software/device to reset it yourself.
If you check out Google there is probably a combination of brake pedal push ons or similar to remove the illuminated icon.
I can now say when you've reached that point, no on the van pedal or switch intervention will work. A trip to Fiat for a OBD hook up with their factory software is required, or , a multiecuscan with a software package that mimics the factory software is required. A OBD reader may well read the fault, but won't allow any resets, only the the two options outlined above work TBOMK.
Mike.
I took it back to the garage and demanded my money back plus expenses. I explained what was wrong, would you believe it 1min 45 secs and it was all fixed and returned to me with many red faces.
