I'm new to motorhoming and new to using gas. Gas being something you have to be a bit careful with I thought I'd ask for some advise before doing something silly.
First of all, are gas systems expected to be 100% leak free? Do you check them regularly? If so, how?
I have an underslung lpg tank with the shutoff valve on the tank itself. I can get to it relatively easily but it involves me laying down on the ground. So how often do you turn this off? Leave it on all the time or turn on/off only when you use it?
How to you measure, or quantify, usage? I have a 25l tank and a gauge inside and I can see if it is full-ish or empty-ish. If we go away in winter I don't want to risk running out of gas. Is there any way I can see we are using x liters per hour or something like that?
