Sat dome does not always receive all channels (2 Viewers)
4maddogs
39
21
North Norfolk
Low profilke
6 months
bit of a perplexing problem. I have been on Mull and found that I could not view Channel 4, Flim 4 or several other channels. I have fta Avtex built in receiver for off grid and also a Humax freesat recording box. I toggle between the two without problem. Both are connected to the dome (independently. I have to disconnect one feed and attach to the TV).
I lost the channels on both systems hence thinking it is the dome....Maxview older system.
I then moved to Moffat on the way home and found I could receive the channels on both systems!
Any ideas?
4maddogs
39
21
North Norfolk
Low profilke
6 months
Bump....no thoughts? I will have to descibe this to a professional, ut hoped someone may have an idea....or a starter for ten?
Jun 18, 2008
1,588
2,281
Lancaster
Since June 2008
Maybe Mull is just on the edge of your dish's reception area and so it locked on to the wrong satellite?
4maddogs
39
21
North Norfolk
Low profilke
6 months
Thanks Linda and Steph. I go to Mull very frequently and it has always been OK before. Some signals may have changed or moved though so I will investigate.
17,635
43,369
the frequencies changed a week or so back so some systems need an update
SATFi
Waterlooville
Vw Camper T2
From our experience with Sat domes this has the symptoms of an LNB failure on one of the polarizations. its any easy fix and to find out you can get an LNB to fit off eBay.
Let us know how you get on.
