Can I safely connect 3 12v solar panels 1x120w, 1x115w& 1x100w (total 335w) together through my Victron 75/15 MPPT controller ?
I know you shouldn't exceed the voltage. But I think having the panels capable of supplying more current than the controller can take is fine. It'll just max out at 15 amps output and the rest goes unused. Like when you plug a low power device into a beefy battery. So when it's really sunny, you won't be getting the maximum benefit.Assuming you plan to connect in series:
You may exceed the maximum voltage (75v) which, according to Victron may damage the controller. Depends on the VOC of the panels. You could also exceed the max amps of 15 which will just cause your controller to reset for a few seconds and try again.
If you connect in parallel:
Voltage-wise you will be fine. You will probably exceed the max amps from time to time and the controller will simply reset and retry.
TBH you’d be better off with a 100/20 and they’re reasonably inexpensive.
Interesting I thought it was for the van.these are the odd wattage panel’s that were sitting in my shed & decided to fit them over the south facing bay window in our house which gets all the sun (when it shines), these via a 200A lithium battery power all the 12v LED
lights in our house - (of which there are 12 (as Sylvia likes ‘mood’ table & side lights) in both the dining & front rooms) ho hum - and of course it drastically reduces mains electricity & saves money so it’s a win win keeping her happy & saving me money!
What I was thinking it would still be isolated just using the existing cabling.No, I’ve no plans to isolate or intergrate the 240v house power, I’ll keep the 12v system totally separate.
The extra power (exceeding the amps) doesn’t go unused, instead the controller stops charging for a short time (as I recall about 10-20 seconds) as the controller resets and tries again. Our experience is that it is not a problem and no damage to the controller. It just means that under ideal conditions (very good overhead sun on a cool day) it spends more time resetting than charging.I know you shouldn't exceed the voltage. But I think having the panels capable of supplying more current than the controller can take is fine. It'll just max out at 15 amps output and the rest goes unused. Like when you plug a low power device into a beefy battery. So when it's really sunny, you won't be getting the maximum benefit.
My brother had a 400w panel on a 30a Victron charger in July sunshine. Ok, not much over, but it just seemed to peg at 30a output.The extra power (exceeding the amps) doesn’t go unused, instead the controller stops charging for a short time (as I recall about 10-20 seconds) as the controller resets and tries again. Our experience is that it is not a problem and no damage to the controller. It just means that under ideal conditions (very good overhead sun on a cool day) it spends more time resetting than charging.
I thought the 30 amp was speced for 440 watt input.My brother had a 400w panel on a 30a Victron charger in July sunshine. Ok, not much over, but it just seemed to peg at 30a output.
You know how Victron rates them? 14.4v times max output amps, (multiply for 24-48v), this is the max theoretical output. In reality you can over panel by quite a bit, as long as you stay bellow rated VOC , and below max amps in. Anything within these parameters the converter is capable to modulate the power down, and take in only what the charger is set to. By default is set to max amps out. You can change that to keep the controller cool if it’s over panelled.I thought the 30 amp was speced for 440 watt input.
