Rubber roof (3 Viewers)
Nov 10, 2008
342
78
Forest Row, East Sussex, UK
5th Wheel
I have a Dicor rubber roof on my 5er and I was thinking of putting a couple of Solar panels on it. How do you fix anything to a RR bearing in mind the WP membrane underneath?
JK
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Linda at Stateside Tuning or Duncan at Star Spangler Spanner would be a good start with advice and suitable sealants etc.
You can't use any old goo with your rubber.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Solar panels on a dicor roof HAVE to screwed using proper mounting blocks, available from (Mark at CLS) a sealant is reqd only to waterproof the screw holes under no circumstances can you rely on sealant alone as the wind lift will without doubts have the panels and rubber membrane off in a jiffy:Eeek:
Geo
ps the correct dicor sealant should also be used
zaskar
1,159
371
5th Wheel
JK
Best for security to screw through the membrane into the structure. it's not recomended to fix heavy objects to any roof just using adhesive.
As far as the rubber roof goes, do NOT under any circumstances use sealants other than EPDM rubber compatable sealants (such as Dicors own self levelling sealant).
Ordinary silicon sealant will initially stick to a rubber roof and leave you thinking that they've worked properly.
I actual fact, one of the properties of EPDM rubber is that it "leaches" agents over its lifespan and consequently, ordinary silicon sealants will lift after 2 or 3 days and leak.
(B8gger, you beat me Geo :) )
12,266
45,055
Nearly Tugging
Last year I fitted a satellite system on my RV I sealed all joints with Dicor lap sealant which comes in tubes suitable for mastic guns. I got mine from ABP Accessories I believe Mobilerv also supply it.
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
:Blush:
PS, what they said re attaching, I kinda forgot that bit and went straight to the sealing bit:Blush::Blush:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
:Blush:
Easy done, Larry too:RollEyes:
I hope he put some screws as well in his dish mount:Doh:
Tony Santara
1,372
116
Cheshire (ex Mancunian)
A class RV
since 1994
Geo
Hey Yoof
I hope that was the correct Dicor sealent that I purloyned from your tool box
:ROFLMAO::ROFLMAO::ROFLMAO:
Feb 22, 2008
12,266
45,055
Nearly Tugging
Yes it was simple . I only mentioned sealing with dicor, naturally mechanical fixing is a necessity.
Larry
