Rotary switch 3 in 2 out option (2 Viewers)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Whatever it does if it is a two out and three in after the third use it will disappear up it's own backside surely
18,036
48,148
Okay.
1 - shore power in
2 - generator in
They can go to all on output 1
3 - inverter - to output 2 ( no Power to battery charger or fridge)
I think you are attacking this from the wrong end. :)
All you need to do is find where the power to the sockets starts so to speak and put a double pole change over switch in at the point. The switch will either take power from the "mains" or the inverter.
In the image below the box with the upside-down triangle is where the 240v coming from the EHU and ELCB is divided up. The white junction boxes are where I've broken into the socket feed. (The bare 12v spade terminal you might see at the bottom isn't normally waving about - I was fiddling with things when I took this. :))
EuroTrotters
Jul 18, 2009
11,201
17,859
HYMER B644
I already have the relay changeover as suggested by @Techno So, when we hook-up, forgetting to switch off the Victron, we have issues. The main one being the surge fuse on the Truma A/C blowing. Arse in the world to change as I have to remove the seat base and seatbelt frame to get to PCB (may have to build an extension to that in for the future).
The Relay changeover worked well with our Merlin Inverter (as did the noisier Contactor from @Clive Mott ) However, with our new Victron, there is not enough delay on the relay. It was the same when I tested a Sterling Inverter.
After speaking with someone abrupt at Sterling, they suggested a Sterling changeover, but they are £300.
11,956
16,571
Delay the relay?
18,036
48,148
Can't you get around the problems with a set procedure for changing over? Turn off any big loads like the AC, then turn off the inverter. Wait a few seconds then change over to EHU.
EuroTrotters
Jul 18, 2009
11,201
17,859
HYMER B644
Yes, until I forget or knock the badly designed switch on the inverter.
Reactions: DBK
