roof plate (1 Viewer)
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
Has anyone fitted checker plate or any other type of covering on there motor home roof?
I have a kayak that i secure to the roof rack which involves quite a lot of plodding about on said roof,although the roof is substantial enough to take my weight it does get slippery and scratched, also worried about dropping something so would like it protected
Tony
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Are you sure you have enough spare load capacity to sacrifice? A lighter treatment might be something by Sika/Sarnafil. They do materials for commercial flat roofs.
Dec 6, 2011
11,605
25,464
South Wales
Coach built Adria
i would agree with Brian that some for of sponge / rubber matting. i try to avoid walking on the roof if possible the concentrated load of toe / heel can over time cause delamination. if i must get on the roof i use my grandsons light weight ( foam ) wave / body board to shuffle around on, save the roof and my knees.:thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Been on many a roof protected as you describe, 1mm aluminium check plate will only add a few KG, It all depends how much roof you want to cover of course, Sikaflex would be my preferred adhesive for a fiberglass roof
there are lots of anti slip paints and stick on products out there that will weigh a lot less though
G
jaygee
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
weight is not a problem as a 4.5 tonn tag axle unit and the alloy tread plate is remarkably light,but not sure what thickness and if any unforeseen drawbacks could occur.
Im not looking to cover the whole roof but just to make a walking area around where the kayak goes.
hdvrod
859
733
devon
since jan 2011
I have chequer plate in front of my roof box been on there years, no problems.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Have you thought about speed liner spray on
The use it to repair shower trays & line pick ups
